XMLReader list creation
  • April 7, 2016
  • 17 views
Hi everyone,
I've got a problem with the XML Reader in FME Desktop 2015. I want to read xml list attributes, and it works fine if a node contains multiple children like:
<feature>
  <networks>
            <network>
                <type></type>
                <linkage></linkage>
            </network>
            <network>
                <type></type>
                <linkage></linkage>
            </network>
        </networks>
</feature>
In this case the reader returns a list networks.network{}, which I need. BUT if networks contains only one network, then it does not return a list, but simple attributes like networks.network.type etc.
My Reader also lists the networks as a list, but in translation it becomes a simple attribute as mentioned. Is there a setting that I am missing?
Feature Attributes:
XMLReader settings:
Thanks,
mel
  • April 7, 2016
Hi @me1, switch the XML Flatten Options dialog to Advanced mode (click the left-bottom button), and modify the cardinality option like this.
cardinality="*/networks/network{}/+ +{?}"
See also here to learn more.
