Hello. Looking for some suggestions on how to fix geometries. These unnecessary vertices are the result of import from MicroStation cadastral based DGN files. The unwanted vertices are on a cadastral grid line.
First case, lines with extra vertex that should be removed:
Second case:2 line segments that should be merged, assuming they are colinear. Would need a test for that, right? In the screenshot below, the short segment south of the green highlighted segment should be merged with the green highlighted segment and defined by 2 points (again, assuming they are colinear).
Third case: polygons with extra vertices like in the line segments. Pt 4 (and others at cadastral grid lines) should be remove (assuming colinear segments):
There are ~25000 lines affected and and similar number of various polygon features.
Thank you for any direction!!
