Illegal operator `A test evaluator was given an invalid test index for evaluation.'
  • October 31, 2013
  • 64 views
After upgrading from FME 2012 to FME 2013 SP1 my workbench now gets the following error at the very end of translation:
Illegal operator `A test evaluator was given an invalid test index for evaluation.' supplied for use in TestFactory -- operator must be one of < > <= >= != = ==
The strange thing is that the translation still completes and writes the output as normal even though I get 'Translation FAILED.'
I've narrowed the problem down by disabling transformers one at a time to a single 2DPointReplacer transformer. It's very strange because its of of about 50 2DPointReplacer transformers in my workbench and they all do they exact same thing. Any Ideas?
Thanks!
  • November 1, 2013
that is indeed strange. My suggestion is to delete the transformer in question and then re-create it from scratch. If that doesn't help, I'd send the workspace to Safe for analysis.
David
gio
Forum|alt.badge.img+15
  • November 1, 2013
as u have 50 2DPR's, you have an input attribute value that does not solely consist of an double.It must be fed to the 2DPR u singled out.
A bit of code where a text is encountered instead of a double/integer will interpret the text as being a variable/paramater and in that case it thinks the =
like x = "5" rather then x =5, must be a comparison, wich of course in tcl is x == "5". ( or !=, <> etc.)
I get this error in different "omissions" on my part when building tcl codes in FME.
therefore i think its in the data u feed the transformer.
  • November 1, 2013
Thanks guys I solved the problem. This was a hard one to figure out because the error does not give any clue as to which transformer is causing the problem. The problem was not with the 2DPR but rather a Tester transformer way further down the line that had the composite test expression of "1 OR 2 OR 3 OR 4" even though I had removed the 3rd and 4th expression from the test clauses leaving them blank.
