JSON Extraction help
louielou1234
Forum|alt.badge.img+5
Hi, sorry for this newbie JSON extractor question but I am using the JASONExtractor transformer and I am trying to populate a column called 'Temperature' and populate it with the value, such as '50' shown below. My query is this: json["beds"].["Weather"].["Temperature"] but this and many, many other variations also do not work. Can someone please, please help me?
"id": 3009,
"beds": {
"Time": "Morning",
"Weather": {
"Temperature": 50
"id": 2969,
"code": "STPAL",
"name": "Acme Co."
Best answer by ebygomm
Not 100% sure on what you are trying to get as your final output, but I'd probably use a JSONFragmenter with a JSON Query as follows, and choose to Flatten Query Result into Attributes
json[*]["name"]+json[*]["STATION"][*]
That will get you this far
erik_jan
Forum|alt.badge.img+18
  • May 12, 2020
This should be possible, using the JSONExtractor, but I prefer the JSONFlattener transformer.
That transformer converts the JSON into attributes and then they are easier to use and manipulate.
Hope this helps.
  • May 12, 2020
JSON query shouldn't be delimited with dot.
Since the sample data you have posted is not a valid JSON document, it's hard to provide an appropriate JSON query. Please post a valid JSON document sample.
louielou1234
  • May 12, 2020
Hi again, I am reading JSON over a web API and have copied what it looks like into the attached text file. Basically, I am trying to extract the number of hospital bed care types ,which then get their own column. Thanks very much for any guidance here!
  • May 12, 2020
This is the full text of the document. Which object do you need to extract?
      "id" : 30,
      "code" : "AUR",
      "name" : "Hospital  1",
      "STATION" : {
         "Time" : "2020-04-11T08:37:05.353",
         "burnunit" : {
            "current" : 13
         "obgyn" : {
            "current" : 3
         "ventilators" : {
            "current" : 29
         "isolate" : true
      "id" : 63,
      "aid" : "551",
      "license" : "0022",
      "code" : "PRC",
      "name" : "Hospital  2",
      "STATION" : {
         "Time" : "2020-05-12T04:06:42.66",
         "burnunit" : {
            "current" : 11
         "obgyn" : {
            "current" : 15
         "vascular" : {
            "current" : 18
         "ventilators" : {
            "current" : 22
         "isolate" : false
      "id" : 29,
      "aid" : "3302",
      "license" : "0066",
      "code" : "TPA",
      "name" : "Hospital  3"
Forum|alt.badge.img+35
  • May 12, 2020
louielou1234
  • May 12, 2020
      "id" : 30,
      "code" : "AUR",
      "STATION" : {
         "burnunit" : {
            "current" : 13
         "obgyn" : {
            "current" : 3
         "ventilators" : {
            "current" : 29
         "isolate" : true
      "id" : 63,
      "aid" : "551",
      "license" : "0022",
      "code" : "PRC",
      "STATION" : {
         "burnunit" : {
            "current" : 11
         "obgyn" : {
            "current" : 15
         "vascular" : {
            "current" : 18
         "ventilators" : {
            "current" : 22
         "isolate" : false
      "id" : 29,
      "aid" : "3302",
      "license" : "0066",
      "code" : "TPA",
Hi Sorry--so I am trying to create columns that show the different types of hospital beds and the number count for them.  So I am trying to get any of the objects in the tier for 'vascular' , ventilators, etc.  Thanks so much again for your time.
louielou1234
  • May 12, 2020
Hmm--I will try looking at your alternate path (sorry newbie here to FME).  THANK YOU!
  • May 13, 2020
OK. @ebygomm has provided an excellent answer. Please follow that.
louielou1234
  • May 13, 2020
OK Got it! --thank you and the others for your help, really appreciate it.
louielou1234
  • May 13, 2020
Thank you!!
itay
Forum|alt.badge.img+17
  • May 13, 2020
The JSONExtractor can be very useful in cases of a static schema.
To make sure you have the right syntax for the query, you can save the JSON from the Data Inspector into a file and temporarily add a JSON reader.
In the reader properties specify a query for your attribute of choice and grab/copy the JSON query the FME so kindly built for you.
Cancel adding the JSON reader and paste the JSON query syntax into the JSONExtractor.
louielou1234
  • May 14, 2020
WOW -- what an excellent approach. We, the JSON newbies, thank you for this quick cheat to getting down to the node we need. Thank you!
