Retrieve an attribute value from another shape in the same workspace ?
  • January 24, 2018
  • 26 views
In a workspace, I retrieve by spatial relation (AreaOnAreaOverlayer followed by a Sampler, SpatialRelator after InsidePointReplacer, ...) an attribute value in a table and a shape that have nothing to do with the table and the source shape.
So I create a second workspace in which I retrieve the previous attribute value in the table and the original shape by a Joiner.
How can I do this in one workspace?
Best answer by takashi
Hi @40_eme, if the table and the shape have a common attribute that can be used as a join key, the FeatureMerger might help you.
  • January 24, 2018
  • January 24, 2018
Thank you Takashi, it's perfect.
dustin
Forum|alt.badge.img+31
  • January 24, 2018
There is also a custom transformer in the FME Hub, Unconditional FeatureMerger. It merges attributes regardless of a join key. I use it all the time for situations like you are describing.
