How to identify short lines that partly duplicates longer line
  • October 31, 2019
  • 7 replies
  • 100 views
I have one feature layer with lines that are not topologically cleaned. There are many lines that are partly duplicated with shorter lines. Except FID, other attributes are the same.
Any suggestions how to identify duplicate polylines (short lines)? LineOnLineOverlayer dont work for me.
Forum|alt.badge.img+49
The LineOnLineOverlayer will split up lines where they overlap, try the SpatialFilter (or SpatialRelator) instead.
Forum|alt.badge.img+33
  • October 31, 2019
After the LineOnLineOverlayer you will want to test for lines wiht overlaps greater than 1, this will return the overlapping segments. If you need to know the IDs of the feature you can build a list
  • November 1, 2019
How to test lines with overlaps greather than 1 ?
  • November 1, 2019
SpatialFilter and SpatialRelator doesnt work too, because all lines are in the same shapefile.
  • November 1, 2019
The _overlaps attribute is automatically generated in the line on line overlayer, then you just need a tester
  • November 1, 2019
In the same shapefile shouldn't be a problem in itself, you can send the shapefile to both requestor and supplier port, and as long as each feature has a unique attribute you can use this in the attributes must differ paramet to avoid each feature comparing against itself. I'd avoid it for this scenario however, as there is no tolerance within this transformer so might not give the output you're looking for.
  • November 1, 2019
Thank You! I will try this.
