finding digitization direction of polyline
  • March 18, 2020
  • 105 views
gis2020
Forum|alt.badge.img+5
Hi All,
i have a polyline for which i would like to find the digitization direction. and based on this i will be applying the driving direction for this line .I am not sure how i can find the digitization direction for polyline , can somebody help me with this .?
I checked with azimuth calculation but not sure how i can use this any guidance on this will be helpful.
Thank you in advance .
danilo_fme
Forum|alt.badge.img+52
  • March 18, 2020
Hi @dandekarpriya
I suggest you to use the transformer CoordinateExtractor.
This transformer generate the attribute _indices - a list of all vertices will be create and the position List{0} - is the begin of direction.
Thanks,
Danilo
gis2020
  • March 18, 2020
@danilo_fme but how can i say if this in positive direction or negative direction ?
Forum|alt.badge.img+46
  • March 18, 2020
How do you define positive and negative? If you know what angles are considered positive or negative you can calculate the angle and then use an attribute creator or attribute value mapper to define positive or negative
danilo_fme
  • March 18, 2020
Maybe you use the transformer AttributeManager and set for the List 0 = Positive:
