Deleting elements in xml file
  • September 3, 2018
  • 193 views
mario_bla
Participant
sorry for this, I have a strong feeling this is for the beginners level but I can't figure it out after 2 hours of trying so maybe someone can show me the right way (I'm also a FME beginner who did only a few workbenches till now).
I need to update an xml file in a way to delete elements based on some condition. For example in this xml file:
<?xml version="1.0" encoding="UTF-8"?>
<bookstore>
<book category="cooking">
  <title lang="en">Everyday Italian</title>
  <author>Giada De Laurentiis</author>
  <year>2005</year>
  <price>30.00</price>
</book>
<book category="children">
  <title lang="en">Harry Potter</title>
  <author>J K. Rowling</author>
  <year>2005</year>
  <price>29.99</price>
</book>
<book category="web">
  <title lang="en">Learning XML</title>
  <author>Erik T. Ray</author>
  <year>2003</year>
  <price>39.95</price>
</book>
</bookstore>
I want to delete all book elements with the year 2005. So the resulting xml should look like this:
<bookstore>
  <year>2003</year>
</book>
</bookstore>
Thank you very much in advanced for any help!
Best answer by takashi
Hi @mario_bla, the XMLUpdater might help you. Note the XMLUpdater always requires a feature input from the Update port, although it's not necessary that the feature contains any relevant attribute in this case.
XML Path setting:
//year[text()='2005']/parent::book
Alternatively, the XMLXQueryUpdater can be used.
XQuery Expression
delete node //year[text()='2005']/parent::book
  • September 3, 2018
XML Path setting:
XQuery Expression
mario_bla
Participant
  • Participant
  • September 5, 2018
Hi @takashi,
thank you very much for your help! I managed to do it following your first suggestion with XMLUpdater. It took me a while because I was always using xml reader and couldn't make the XMLUpdater to do its task. Than I used the txt reader instead and read the xml file as a plain text (with parameter 'read whole file at once' set to 'yes'). When I did that, workbench ran successfully.
  • September 6, 2018
Hi @takashi,
Good to hear.
Additions.
1. You can also read the source XML file with the XMLUpdater directly.
2. This XPath is also available in your case.
//book[child::year/text()='2005']
