Overlapping clippers
  • November 14, 2012
  • 6 replies
  • 38 views
Forum|alt.badge.img+62
I'm using overlapping clipping features and I'd like any clippee features that are either INSIDE or CLIPPED_INSIDE more than one clipper feature to receive the attributes from all clipper features they're affected by. I thought I'd done this succesfully before, but it looks like I can't get it to work, the clippee's get the attributes from the first clipper feature, if they're vector features. Rasters behave exactly as I want them to.
  • November 14, 2012
Forgot to add: "does anybody have an idea how to solve this?"
fmelizard
Forum|alt.badge.img+21
  • November 14, 2012
Did you try rasterizing your vectors?
wisegis
Forum|alt.badge.img+17
  • November 14, 2012
Have you made sure you are running multple clippers in the parameters of the Clipper transformer.  Also, I would right click on the writer and add (copy) the attributes from the feature class in question.
  • November 14, 2012
@Itay: not an option, I need both vector and raster data.
@Clay: Yes, set to multiple clippers. It's putting the attributes through just fine, that's not the issue, it just seems that when a feature is affected by more than one clipper it's only clipping to the first one and ignoring the others.
sigtill
Forum|alt.badge.img+25
  • November 14, 2012
Which version of FME are you using (2012 or 2013?). I had some problems with the Clipper in 2013 - however can not find my notes regarding that.
I also assume you have unchecked/checked the option:
Create Aggregates
"If the Create Aggregates parameter is No, then features that are clipped into multiple parts will not be aggregated, but rather each part will be output as a separate feature."
  • November 14, 2012
@Sigtill, it seems to be happening from FME 2011 SP4 all the way to 2013. Yes, I did look at that Create Aggregates option, but that's not making any difference for my problem.
