Finding gaps in time series
  • November 9, 2017
  • 187 views
Forum|alt.badge.img+4
Can anyone suggest a way to use FME to find gaps in a daily time series?
I'm looking to generate a report for missing days of data in an effort to QC a dataset and know there must be a way to do this, right?
erik_jan
Forum|alt.badge.img+26
  • November 9, 2017
If you are using FME 2017 you can calculate the difference between two dates.
So, if you sort the data, you can compare the date of the current record with the date of the previous record (Using AttributeCreator as in the image):
Then use the DateTimeCalculator to calculate the difference.
If the difference is larger than 1 (Tester) you have a gap in the dates.
  • November 9, 2017
So if I have a time series of days like this:
DATE01-01-201601-02-201601-03-201601-31-2016
I would create a new attribute, let's call it DATE_PREVIOUS_RECORD, grab the value from the previous record and populate it like this:
DATEDATE_PREVIOUS_RECORD01-01-2016<null>01-02-201601-01-201601-03-201601-02-201601-31-201601-03-2016
Then use the DateTimeCalculator to calculate a difference between DATE and DATE_PREVIOUS_RECORD, and if >1 then do something, right? I'm going to try this out now, thanks!
In FME 2017 take a look at the DateTimeCalculator transformer - it lets you add/subtract or calculate intervals, or construct an expression. It assumes the values are in FME format, so use the DateTimeConverter beforehand to convert your data to that format.
  • November 9, 2017
Yes, I think you are on the right track. Next, as @1spatialmary suggested, you can format the date strings into the FME standard date representation (%Y%m%d) with the DateTimeConverter, and then calculate the interval days between the two dates with the DateTimeCalculator (Mode: Calculate Interval between Datetimes).
Alternatively, you can use FME Date/Time functions effectively, like this.
@DateTimeDiff(@DateTimeParse(@Value(DATE),%m-%d-%Y),@DateTimeParse(@Value(DATE_PREVIOUS_RECORD),%m-%d-%Y),days)
See here to learn more about FME Date/Time Functions: Date/Time Functions
