Remove redundant vertex in a polygon
  • November 6, 2017
  • 408 views
Hi together
I get a lot of polygons and some of them have redundant vertex point coordinate!!!
How can I remove the redundant points in this polygons?
Thanks
Zoran
Best answer by redgeographics
The GeometryValidator that @david_r suggests can remove duplicate points. In case you have unneccessary points (i.e. they have no influence on the actual shape of the object, but they're not duplicates) you can try a Generalizer to get rid of those.
  • November 6, 2017
You can use the GeometryValidator:
Forum|alt.badge.img+62
  • November 6, 2017
helmoet
Forum|alt.badge.img+8
  • November 6, 2017
Hi, not sure what you mean by redundant vertex point coordinate, it might also be some spike, which can be removed by FME using the SpikeRemover, as in the picture below:
erik_jan
Forum|alt.badge.img+26
  • November 6, 2017
The Generalizer can also be used if the redundant point is not exactly on top of another.
