METADATA CAD TO GIS
  • May 4, 2013
  • 20 views
HI ALL..
I HAVE ONE QUESTION ABOUT METADATA MANAGEMENT USING FME. IS THERE HAVE ANY TOOLS IN FME THAT CAN SUPPORT METADATA FROM CAD TO GIS?I'M SURE THAT ARCGIS PROVIDE THE TOOLS TO STORE THE METADATA OF THE DATASET, BUT CAN WE USE FME TO TRANSFER THE METADATA FROM CAD DRAWING TO GIS?THANKS..
  • May 5, 2013
as a start, have a look at the two videos on this page, showing how to read and write metadata using FME.
The same page also links to a saved webinar on FME and metadata.
David
  • May 15, 2013
If we want to attach the xml metadata with feature data in GIS using FME, how can we do?as the result, the feature class has already with metadata when opened it at ArcCatalog.
