DWG to ESRI file gdb - Ellipse features
  • September 15, 2017
  • 26 views
Greetings,
I am trying to export ellipse features to an ESRI file gdb.
1)
Do they need any processing by a transformer first??
2)
Should they be exported as a line or polygon??
Any suggestions appreciated.
Best answer by courtney_m
You do not need to do any processing first - just make sure you only have ellipses, then write to the GDB. I just ran a test to make sure, and you can write the ellipses as either polylines or polygons. You will just need to set the geometry on the writer feature type.
courtney_m
Forum|alt.badge.img+22
