dwg to S-57
  • January 30, 2013
  • 23 views
Hi All,
I work in an office hydrographic and my work is to create electronic navigation charts and my problem is transformation from dxf/dwg into S-57 with FME.
I could not transform a dwg in S-57. I tried to make this transformation from bathymetric polylines - dxf/dwg format into S-57-lines format. The end result should be an S-57 lines with some attributes about depth.
Thanks
fmelizard
Forum|alt.badge.img+21
  • January 30, 2013
According the documentation FME does not have a S-57 writer, so that can be a problem...
  • January 30, 2013
hi itay, I understand now, I must transform in esri shapefile then in S-57!!! But I don't know Joe!!! There are some tutorials about shp to s57? Thank you for answer!!!
fmelizard
  • January 31, 2013
Hi Teditzakis,
I think you misunderstood, FME can read S-57 but cannot write it.....so converting to S-57 is not possible.
