Extract coordinates of linear feature
  • January 23, 2013
  • 5 replies
  • 120 views
I have a requirement of extracting every coordinates <ORDERED LIST OF VERTICES FROM 1 TO N> of linear feature. Can any one please suggest the approach of extractig coordinates.
Thanks,
Seshu
Best answer by takashi
This custom transformer might help you:
http://fmepedia.safe.com/articles/Samples_and_Demos/Custom-Transformer-that-Exposes-all-Vertices
  • January 23, 2013
  • January 23, 2013
Thanks Takashi, This is the exact transformer that I am looking. It fulfills my requirement.
  • December 5, 2014
I used this custom transformer to extract coodinates from an ESRI-annotation feature class without success. My annotations refer to baselines consisting of 2 points and the result is one point (midpoint) for each annotation. How can I extract all coordinates and create lines?
jaro
  • November 4, 2015
Hello Takashi, the page is now removed, would you please suggest where to find the transformer?
  • November 4, 2015
@jaro, I cannot find the page, but the transformer - VertexExtractor is now available in FME Store. In many cases, you can also use the Chopper (Mode: By Vertex, Maximum Vertices: 1).
