Create circle in GML
  • June 13, 2017
  • 53 views
zzupljanin
Forum|alt.badge.img+5
Is it possible to write and read circles (curves and arcs as well) in GML format.
Forum|alt.badge.img+62
According to the GML quickfacts circles and arcs are not supported. From what I gathered they are part of the GML specs though, so maybe you should enter this as an Idea
zzupljanin
  • June 13, 2017
yes, I've also read that. Can it be done using GML applications schema?
soeren
Forum|alt.badge.img+7
  • June 13, 2017
all three types are currently supported. Here (gml2gml.fmwt) is a Workspace that reads and writes a Circle and different types of Arcs. However there are limitations. Example: Unit of Measure is not supported in ArcByCenterPoint or CircleByCenterpoint.
zzupljanin
  • June 13, 2017
Yes, that's what I need. I was somewhere around using GML encoding but couldn't figure it out.
Thank you, sir
PS. I reckon working with splines is somehow similar?! Gonna give it a try. Cheers
