Troubles when using WorkespaceRunner
  • December 19, 2013
  • 35 views
Hi everyone
I run an image clipping workbench (let's call it clip.fmw) from another workbench (starter.fmw) using WorkespaceRunner. But I am unable to put the parameters in the right format in order to get the clipping done right. I did some testing:
Starting by using the starterfmw skript with the WorkespaceRunner that runs clip.fmw:
in the starter.fmw skript:
Klicking on the (...)-button in the workspaceRunner to select my images I get following result (when selecting multiple images):
In the picture selection window:
"picture1.jpg" "picture2.jpg"
In the WorkspaceRunner Parameter Window:
In Log window when running the WorkspaceRunner out of the starter.fmw:
--SourceDataset_JPEG {""E:\\picture1.jpg" "E:\\picture2.jpg""}
--> The Skript Fails
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
In clip.fmw skript without using a WorkespaceRunner:
double clicking on the .jpg reader source files and againg on the (...)-button - I get following result:
In the Edit-Parameter Datasource Window:
In log in:
fme.exe starter.fmw (the blue log at the start);
SourceDataset_JPEG """""E:\\Ortho_2012\\588937.5_196700.0.jpg"" ""E:\\Ortho_2012\\588937.5_197000.0.jpg"""""
--> SUCCESSFUL
When I copy and paste the last argument with all the """" in the starter.fmw WorkespaceRunner it fails as well...
I think FME is trying to put my inputs from starter.fmw in the "right" format asbut is not able to or mixes up all the "" . I would really like to pass the arguments using text and commas only but this does not seem to work.
Thank you for your help!
Best answer by simon11
Hi Takashi. Thank you for your answer. Becaus of your hint i went a bit deeper in the log and started to create a new and simple workspace from srcatch to provide you some useful logfiles.
When creating my new workspace I realized that there was a versionchange in WorkSpaceRunner transformer since I started my old skript where I still used version 0. In the new version 1 of WorkSpaceRunner the transformer expects the inputattribute to be like this (to read jpgs at least):
""Image1.jpg" "Image2.jpg" "Image3.jpg" "Image4.jpg""
in text this means:
The filenames enclosed in quotation marks on both sides separated by a space. The whole statement is enclosed in two quotation marks as well.
With the input formatted like this it works!
The same input will not work in transformer version 0.
Thanks again for your help (or pushing me in the right direction)
  • December 19, 2013
Hi, could you please post the error message logged in the log file (clip.log)?
  • December 20, 2013
in text this means:
