I Get an error in my workflow: expression: edgecurves_[edge].has_value() error
jan-henk
I can nowhere find information for this error?
Does someone know how I can fix this?
Stored 82 feature(s) to FME feature store file `C:\\Users\\CENTRA~1\\AppData\\Local\\Temp\\wb-cache-03_Buffers_Bouwen-xPalBe\\Main_LineCombiner -1 152 fo 0 LINE 0 932eff0b162b454a4c8fc28137d419000e8ade26.ffsupdating'
Saving spatial index into file 'C:\\Users\\CENTRA~1\\AppData\\Local\\Temp\\wb-cache-03_Buffers_Bouwen-xPalBe\\Main_LineCombiner -1 152 fo 0 LINE 0 932eff0b162b454a4c8fc28137d419000e8ade26.fsi'
Finished saving spatial index into file 'C:\\Users\\CENTRA~1\\AppData\\Local\\Temp\\wb-cache-03_Buffers_Bouwen-xPalBe\\Main_LineCombiner -1 152 fo 0 LINE 0 932eff0b162b454a4c8fc28137d419000e8ade26.fsi'
Expression: edgeCurves_[edge].has_value()
FME Session Duration: 2 minutes 17.7 seconds. (CPU: 114.9s user, 19.7s system)
END - ProcessID: 8116, peak process memory usage: 299160 kB, current process memory usage: 105972 kB
Program Terminating
Translation FAILED.
Best answer by DanAtSafe
ewanrobertmclau wrote:
Using FME 2020.1 and I am getting this error. Occurs when using 'Arc' as corner and end cap and then dissolving with a dissolver.
Hi @ewanrobertmclau​ Yes, unfortunately this is still an outstanding issue. Please file a case and send us some sample data if you can. Meanwhile, use an ArcStroker and avoid the arc cap and corner styles in the Bufferer. We also hope to improve the error message.
mark2atsafe
Forum|alt.badge.img+43
  • March 23, 2020
That looks like a definite bug to me. Can you send your details to the support team (or to your local reseller, if you have a support contract with one)?
Please include as much information as possible, including the full log file, the workspace, and data (if you are able) so that they can replicate the problem.
You could also mention that it might be related to FMEENGINE-63495 (in which case it would be fixed in 2021 already, and we could perhaps backport that fix to a 2020 build).
  • March 26, 2020
@mastertree I do not have an answer to why that issue is happening but I was able to work around the issue by simply changing the end cap style and corner style to square and miter respectively in my bufferer transformer parameters.
This issue seemed to arise with the installation of FME 2020.
  • March 27, 2020
@mark2atsafe I receive the same error when using the dissolver.
I added a geometryvalidator, and tried to repair it but the error happens at the same point.
I upgraded recently from 2019.2 (b19801) to 2020.0.0.1 (b20202). The workbench was created in 2019.2. It takes input (feature class) from another workbench that ran in 2020.0.0.1.
There are no upgradeable transformers up to the dissolver on which it crashes.
I can share my wokrbenches and input data
mark2atsafe
  • March 30, 2020
I really can't tell what would cause that sort of message. I think the best solution is to send the details to the FME support team (or to your local reseller, if you have a support contract with one). I think that's the only way to get a resolution. I don't see that error mentioned anywhere before this.
Please include as much information as possible, including the full log file, the workspace, and data (if you are able) so that they can replicate the problem. And if we try it in 2021 and it is OK (which I suspect) then we'll know that there is a fix we can easily apply.
I had the same problem. Actually, when I upgrade Bufferer transformer it takes Arc as area parameter for end cap style and corner style. That gives an error (the same mentioned above) if I want to dissolve. The solution was for me also to change the bufferer parameters.
  • April 24, 2020
We encountered the bug again. It must be related to the bufferer. I can't recall, but it could very well be that using the dissolver after the bufferer creates an issue. We are trying different buffer methods to see if that avoids the crash. We will send the workbench and data to support.
jovitaatsafe
Forum|alt.badge.img+11
Hi @haanjohan,
yes please do if you haven't already. And as Mark mentioned, you can reference FMEENGINE-63495 which has a fix for FME 2021.0 and we can ask to see if that can be backported to FME 2020 to be made available earlier. Thanks!
bsw-gis
Participant
  • Participant
  • May 4, 2020
Looks like using the Bufferer before the Dissolver is at issue; at least in my case. The workaround for me is now replacing the default endcaps & corners to 'Round' from 'Arc'.
The Bufferer can now 'Dissolve on Attributes' so getting rid of the Dissolver may solve the issue for most ppl. However, in my case, I cannot do that as I am adding geometry from another source and have more than one connection into the Dissolver that need not go through the Bufferer.
That worked fine! Thanks. I had the same issue.
chriswilson
  • August 27, 2020
I'm getting this at the dissolver stage, no bufferer in my workspace. Solved by adding a bufferer with buffer value zero and changing end cap style to square and corner style to miter as per the workaround earlier in this thread.
I'm on FME(R) 2020.1.0.1 (20200710 - Build 20596 - WIN64) and below is the original workspace before I put in the bufferer.
 2020-08-28 10_06_58-NONE → MULTI (__wanda_arcgis_Property Maintenance_FME Import to Subdivision Lots
brandonguo
Forum|alt.badge.img+3
  • September 24, 2020
I am getting the same error using the buffer transformer, the buffer just has so much unknown bugs.
oliver.morris
Forum|alt.badge.img+12
also getting this same issue. AreaGapAndOverlapCleaner followed by Bufferer, change to square and miter and still have issues unfortunately. tested on 2010.2
chrisatsafe
  • September 25, 2020
Hi @oliver.morris​ ,
Can you try this on the latest FME 2021 beta release? It looks like a fix was released for this a few months ago.
chrisatsafe
Hi @brandonguo​,
Are you getting the same error in FME 2020.1? This should have been fixed in builds b20605+ (including the 2020.2 and 2021 betas). If you are still seeing the same issue in any of the latest builds please let us know so we can re-open the reported issue.
koenterralytics
Forum|alt.badge.img+8
Same issue here using 2020.1.1.1.
gav
Forum|alt.badge.img+10
  • December 10, 2020
Also had this issue (with Bufferers leading to Dissolver.) Applied the same workaround as above (End Cap and Corner styles to Round), which allows me to get around the bug.
FME2020.1.0.1, build 20596, win64
ccomeau
  • January 5, 2021
FYI: Using FME(R) 2020.1.0.0 (20200707 - Build 20594 - WIN64)
The error Expression: edgeCurves_[circuit[0]].has_value() appears using the Dissolver on a medium
database of polygons. (103 225)
helmoet
  • January 21, 2021
Hi, I reported the same error in FME 2020.2.0.0, Safe confirmed that it was fixed in FME 2021. I worked around the issue by buffering without the dissolving stage and adding a separate Dissolver transformer.
matthew_banyard
Exactly the same situation and error message here - Workspace built in 2019, upgraded to 2020.1, including upgrading the upgradeable transformers through FME's wizard.
Workspace containing several bufferers, including a bufferer followed immediately by a dissolver, with settings previously set to Arc (no specific reason why Arc was being used, could happily be Round).
I removed the upgraded Bufferer and Dissolver Transformers, and replaced them with new ones - with Buffer parameters set to Round instead.
DanAtSafe
Forum|alt.badge.img+18
  • May 21, 2021
  • May 28, 2021
I'm facing the same problem of getting the edge curves error when trying to dissolve, and also do not actually need to buffer anything in my workspace. The workaround seems to be valid and the bufferer does not alter the geometry with those parameters set from what I can tell. Did you confirm that this is the case?
Cheers,
Nate
hansb
  • June 10, 2021
Got the same error ... checked Dissolvers in workspace and added Bufferers as mentioned - did not work for me. Hmm? Decided to go the hard way and split my dataset by half again and again and in the end found one (!) single polygon out of 10.000 which had a triple vertex what in fact caused FME to stop.
It seems this issue comes up if the input data is defect, maybe edgeCurves_[edge].has_value() means there is no curve between 2 vertices.
The buffer solution may help to go around that issue but in my case it was much easier to check source geometry integrity - after deleting 3 unneeded vertices everything was fine.
DanAtSafe
  • June 10, 2021
@hansb​ Could you find and repair the problem feature with a GeometryValidator?
koenterralytics
@danatsafe​ , I tried the GeometryValidator last year (2020.1) but it didn't solve the issue for me
