I would like to use ArcGIS API for Python in an workspace running in FME Server Cloud. For that I need to use the Conda-interpreter. Is it possible to use Conda in Cloud, if so what are the steps to achieve this?
Conda-interpreter in FME Server Cloud
Best answer by gerhardatsafe
Hi @erikb,
This is currently not possible on FME Cloud, because the user does not have administrative access to the underlying OS. So users can't install any 3rd party libraries on FME Cloud. They can only interact with the instance via the FME Server UI.
If you can share more details about your use case we can look into potential options or workarounds for this. I doubt that we would be allowed to add the ArcGIS API for Python programmatically to FME Cloud instances but I am not sure.
But I would be very curious about the scenario and would be to look into this in more detail.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
