Fatal error message during export from MicroSation GeoGraphics format. Access querry feiles.
  • May 3, 2017
  • 15 views
During export from MicroStation GeoGraphic I get this error message from the GG-reader:
Microsoft Access Reader: Opening `H:\Produksjon\Kart\2017\Roar_data\Prosjekt\Data\Testdata\Input\TAB\ParksExport.mdb' for read operation
Microsoft Access Reader: Query failed, possibly due to a malformed statement.  Query Text `SELECT * FROM PARKS WHERE PARKS.MAPID = (SELECT MSLINK FROM MAPS WHERE MAPS.MAPNAME LIKE 'ParksExport.dgn')'. Provider error `(-2147217865) The Microsoft Access database engine cannot find the input table or query 'MAPS'. Make sure it exists and that its name is spelled correctly.'
A fatal error has occurred. Check the logfile above for details
@Relate: Failed to execute prefetch query. Continuing with incomplete cache
Microsoft Access Reader: Database read complete.  Retrieved 1 feature(s)
This happens for several Reader formats.
I converted Parks.tab from the training dataset, to GG, and tried to convert back to TAB.
The errormessage comes from the GG-reader.
- What makes this happend?
-Does i cause any real problems? (data seems OK)
  • May 3, 2017
Could it be that the mdb is incomplete? If you open the mdb file using MS Access (or using FME and the Access reader), do you see a table called "maps"?
Here's more info about the metadata tables that are expected:
http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/mge/mge.htm
Thanks for answer!
There is no table called "maps". There are Feature, MSCATALOG, PArks and UGGEATURE.
In Parks there is a coloumn called MAPID, but all records are emty.
The problem is why the MAP table is not created. My tests WS's have only two elements a reader and a writer.
