I have created the below global temporary table on our development schema, and within the FME workbench, I am trying to create an ARCSde reader that will use this table.
CREATE GLOBAL TEMPORARY TABLE myglobal(
IGEOM ST_GEOMETRY,
HU100 NUMBER,
POP100 NUMBER,
POPPEP NUMBER
) ON COMMIT PRESERVE ROWS;
When I attempt to create the reader, I receive the below error message:
An error occurred while attempting to open the table, feature class or relationship class 'myglobal'. The error number from ArcObjects is: '-2147155648'. The error message from ArcObjects is: {Abstract Data Types not supported [myglobal][STATE_ID = 24]}
I tried creating the table with the ST_GEOMETRY column and then creating a reader to access the table within the FME workbench and there were no issues. Is there something special I need to do to work with ST_GEOMETRY? I'm encountering a lot of issues using that type, whereas I encountered none when using SDO_GEOMETRY.
Thanks very much.
Joe
