how to find lines with atleas two vertices common
  • September 26, 2013
  • 39 views
Hello Everybody,
If anyone can help me to find the lines with atleast two vertices common as i need to make offset of these lines. I used duplicate remover ,it works fine for lines having only two nodes (i.e start and end) but as in my line network there are lot of lines which has various cases like 1st and 2nd vertices common or 2nd and third vertices common .
I need to offset all the lines if they are having same two vertices. Please help
Thanks in advance
Best answer by gio
an open question? amazing!
Make sure u have a line ID or something.
Use chopper, whith number vertices to 1.
Make a list grouped by  x,y coordinates.
Now u got your lines.
gio
Forum|alt.badge.img+15
  • November 25, 2013
