autocad object data
Hi All,
does anyone have experience with importing the 'autocad object data' format? When I open the file in the inspector, I can see the attributes with its values in the table. However, when I open the file in Workbench and just connnect inspectors to them, I do see the attributes but all the values are on <missing>. An AttributeExposer doesn't help. Any ideas?
best regards,
Jelle
pratap
Forum|alt.badge.img+11
  • May 6, 2015
Use the reader with "Autodesk AutoCAD Map 3D Object Data" and enable required format attributes...
  • May 6, 2015
Hi Pratap,
thank you for your answer. That is the reader I have been using all the time. What do you mean with 'enable required format attributes'? I can't find an option like that in the reader parameters.
gio
Forum|alt.badge.img+15
  • May 6, 2015
You must expose the required Autocad attributes.
You can either do this on the reader, in the format attributes tab, or anywhere useing exposer or just entering the format-attribute name  exactly as you see them in the FeatureInformation panel.
Some, light objectdata, may be lists.
Hello, have you some result with this question? I have similar problem with "autocad map 3d object data" reader
https://knowledge.safe.com/CommunityAnswers?id=906a0000000dB9tAAE
jelle
Forum|alt.badge.img+16
  • May 20, 2015
in the end, it turned out that the supplier had to change the way of saving the attributes in the DWG file. Unfortunately, I don't know the details how they solved the issue.
pratap
  • May 22, 2015
'enable required format attributes' means you have to enable the attributes in the FORMAT ATTRIBUTES. Go to reader, right click and select the Properties, you will be having tabs with names general, user attributes and format attributes. enable the object data attributes some thing like extended data or object data
