COnvert format
  • April 27, 2020
  • 25 views
joseotaviobisca
Is it possible to transform a RASTER file into MBTiles format using FME? For example GEOTIFF raster to MBTiles format.
Is there a tutorial on youtube?
jdh
Forum|alt.badge.img+40
  • April 27, 2020
It could be as simple as adding a geotiff reader and an MapBox MBTiles Writer and connecting the two.
joseotaviobisca
Excellent, thank you very much. I had seen the MAPBOX MBTILES page, but I wanted to be sure of this possibility because I am doing a job to buy the FME and one of the needs is to transform GEOTIFF into MBTILES. Thank you very much.
