Hi folks- I have a polyline file (in planar coordinates) and attempting to build a 200ft buffer around each line. Simple, but I am repeatedly getting the error: Cannot write a non-area feature to an area feature class. The bufferer seems to be writing out polygons...fme_geometry is showing polygon. I've tried geometrycoercer, attribute exposer, geometry validator...all successful in saying the polygon geometry is legit. I can even write successfully as a polygon shapefile. But not to a fGDB polygon feature class.
