This seems to me to be quite a ridiculous problem, but I can't find a way to solve it. I have an attribute that comes from an Apache 2.2.25 API connected through a HTTPFetcher that I need to split into a number of new attributes. This is an exapmle of the attribute with the kind of data it contains (alsways numbers of vaying lenght separated by "/"):
Attribute X
12345
12345/123456
12345/123456/12345
123456/12345
What I need is this result:
Attribute X                           AttributeNew1      AttributeNew2      AttributeNew3
12345                                 12345                    <blank>                 <blank>
12345/123456                  12345                    123456                  <blank>
12345/123456/12345      12345                    123456                 12345
123456/12345                   123456                  12345                   <blank>
What I get now is this:
12345                                 <blank>                 <blank>                 <blank>
12345/123456                  123456                  <blank>                 <blank>
12345/123456/12345      123456                 12345                    <blank>
123456/12345                   12345                   <blank>                 <blank>
In other words, the splitter does not transfer the first value to a new attribute. I've been trying a lot of different approaches without any luck. Ant ideas on what to do?
Thank you!
Chris
the results of the splitter are stored in a list, you can copy the list element values into new attribute values or explode it to new features.
Itay is right. Try splitting the attribute value at slash (AttributeSplitter), and renaming individual list elements (AttributeRenamer).
_list{0} --> AttributeNew1
_list{1} --> AttributeNew2
_list{2} --> AttributeNew3
Takashi
Of course! There can be up to 50 numbers in that attribute, so my list gets pretty long. Now I see that i startet the renaming at _list{1} instead of _list{0}. I knew this was a ridiculous problem. :) Thank you both for the feedback!
Chris
