If the xml file is not valid or doesn't exist I get an error:
0.0|ERROR |XML Parser error: 'unable to open primary document entity 'file: ....
but the translation continues with the invalid feature being dropped.
Is there anyway to record those features. Ideally I would like to write a text file with the path of all the invalid xml files.
Joanna
