How to replace string? From "Toi et Moi (Villa)" to "(Villa) Toi et Moi"
  • September 19, 2018
  • 7 replies
  • 32 views
Hi FME experts,
I'm having difficulties updating below:
Left is what I currently have, right is what I'd like to have. Have Want Toi et Moi (Villa) (Villa) Toi et Moi Wilgenerf ('t) Landhuis ('t) Wilgenerf Landhuis Gheestelic Hof (Het) (Het) Gheestelic Hof
So if it finds anything in between brackets, take that and put it in front of the string.
I've been trying the StringReplacer with the following RegEx: (\\(.*\\)) - but no luck so far.
Cheers,
Ed
Best answer by david_r
Try the following in a StringReplacer. Text to replace:
(.*)\s*(\(.*\))
Replacement text:
\2 \1
(.*)\s*(\(.*\))
Replacement text:
\2 \1
(.*)\s*(\(.*\))
Replacement text:
\2 \1
Hi @david_r
I'm getting \2 \1 as a string instead of referring to the capturing groups?
Strange. Which FME version are you running?
Beta 2019.0.0.0
Mmmm, could that be it? Let me try a different version.
Beta 2019.0.0.0
I did my testing with the very latest FME 2018, for what it's worth.
@david_r
It appears the 2019 beta is the problem!
2018 works:
@david_r
2018 works:
Fantastic! Sounds like a mail to Safe support is in order...
