Counter behaving strangely
  • January 2, 2020
  • 8 replies
  • 40 views
I am using FME 2019.1 and have encountered a strange issue with the Counter transformer.
I am getting the below value being returned in the _count attribute for some but not all records. Just prior to the Counter transformer I reversed the orientation of a few records and I have found that for those records which are reversed, I get the below value output, but for those which are not reversed, I get a normal number output. However, when I pass only the reversed records through the counter, I get normal number outputs. It doesn't seem to like the combination of reversed and non-reversed records!
@Value(__fme_ft_return_value112f8e69-4aa4-4f5f-9f81-f47c60797f64)
Has anyone seen this before?
Forum|alt.badge.img+62
Could you share a screenshot of your workspace so we have a better idea of what you're trying to do?
  • January 2, 2020
Hi @redgeographics below is a screenshot.
Counter_4 is the one that outputs the strange values. Counter_3 works as normal.
I can't seem to reproduce this, I've attached my little testcase if anybody else wants to take a stab at this (or if you want to send it in to Safe's support).
If you could try running that test workspace and see if you get the correct results that could actually be quite useful (it may be an issue with your source data)
Counter_issue.fmw
  • January 2, 2020
Counter_issue.fmw
Thanks for looking at this @redgeographics. I ran that workflow you sent through and it worked fine for me. But when I copied the transformers into my existing workflow and connected it up , I got the same issue. I have now found a work-around which means I don't have to use the Counter anymore...
jonathanklarup
I'm having almost the same issue. When counting the result from sql executor it returns whats seen in the inspector, but counter works fine for the initiator.
What was your solution @aquamarine ?
Thanks in advance
Forum|alt.badge.img+46
  • February 4, 2020
Thanks in advance
I wonder if this is related to the bulk mode issue that was affecting the statistics calculator
https://knowledge.safe.com/questions/102959/incorrect-results-from-statisticscalculators-cumul.html
If you put a python caller in front of it (doing nothing) does it fix it?
fmelizard
Forum|alt.badge.img+21
  • February 4, 2020
Thanks in advance
Hi @jonathanklarup Try a PythonCaller as @ebygomm suggested, or an Offsetter, or an AttributeKeeper - all of these are transformers which will split up the feature tables. See the explanation here: https://knowledge.safe.com/questions/105599/why-is-my-counter-transformer-giving-me-a-weird-va.html
jonathanklarup
worked like a charm, thank you @danatsafe
