I need some help with a linear referencing issue I'm having.
I have feature merged a series of CSV entries to a DGN line as a List and then exploded them out into a Visualiser. Everything looks normal, there are 33 individual entries when I click on the line. However when I push those through a Snipper, they are all rejected and I can't figure out why. It's near identical to a workspace I've run before, and I can't work out what's different! The table that goes to the Snipper has a Chainage which I've set as the Start and End on Distance (Value). Why are they being rejected?
That's the first issue, the second is that some of the features need to be lines where the Start is the Chainage and the End is the next Chainage. I've filtered these out to a different strand and connected them to an AttributeCreator where I've activated the Enable Adjacent Feature and set prior to 0 and subsequent to 1, Attribute Name to Chainage, but not sure how exactly this works as the output just gives an empty Chainage. Is this transformer supposed to add a new Chainage value (i.e. the end value of the line)?
Thanks very much.
Amit
