atan2(@Coordinate(y,0)-@Coordinate(y1),@Coordinate(x,0)-@Coordinate(y,1))
It used to work in FME 2012.
I published the workspace from FME 2013, and suddenly it says invalid character "@":
2014-03-18 20:58:38| 53.9| 0.0|WARN |LineTerminator_GetRadianRotationAtP1: Failed to evaluate TCL expression: @Coordinate(y
2014-03-18 20:58:38| 53.9| 0.0|WARN |LineTerminator_GetRadianRotationAtP1: TCL Error Message: invalid character "@"
in expression "@Coordinate(y"
1. Does FME 2013+ prohibit @functions from being used in ExpressionEvaluator transformers?
2. Is there new syntax to get it to work?
3. What is the best way to get the angles of the first and last segments of a line geometry?
Thanks,
Brad
