combine list in one feature
  • June 8, 2018
  • 169 views
boubcher
Forum|alt.badge.img+11
How can I combine a list of the same feature into the same one
From this
Ply_idLoc_nameLayer_idSpatial_relation1MTL1510OVERLAPS1MTL1511OVERLAPS1MTL1512WITHIN
to this
Ply_idLoc_nameLayer_idSpatial_relationMsg1MTL1510 OVERLAPS, 1511 OVERLAPS, 1512 WITHIN
Thanks
Best answer by erik_jan
First use the StringConcatenator to create Msg for each line.
Then use the Aggregator (group on Ply_id and Loc_name) to create 1 feature.
Use "Attributes to Concatenate" to create one comma separated message.
erik_jan
Forum|alt.badge.img+26
  • June 8, 2018
boubcher
  • June 8, 2018
@erik
Thanks
boubcher
  • June 12, 2018
@erik_jan
why I am not getting the geometry value when I use geometry extractor after the aggregator transformer
erik_jan
  • June 12, 2018
@erik_jan
What aggregation mode are you using in the Aggregator?
See: Aggregator documentation
