SQLExecutor issue
  • September 4, 2019
  • 5 replies
  • 236 views
I am trying to use SQLExecutor to either insert or update a record in a table stored in Oracle - please see sql below. It gave me the following error. any ideas why?
declare
counts int;
begin
select count(*) into counts FROM employee where emp_id = '@Value(empid)';
case
when counts = 0 then INSERT INTO employee VALUES ('@Value(empid)','@Value(firstname)');
when counts = 1 then UPDATE employee SET firstname = '@Value(firstname)' WHERE emp_id = '@Value(empid)';
end case;
end;
An error occurred while accessing a table result for feature type `'; message was `Execution of statement '
did not succeed; error was `ORA-06550: line 7, column 14:
PL/SQL: ORA-00933: SQL command not properly ended
ORA-06550: line 6, column 30:
PL/SQL: SQL Statement ignored
ORA-06550: line 9, column 4:
PLS-00103: Encountered the symbol ";" when expecting one of the following:
Best answer by david_r
Was this error raised for the first feature, or during further processing?
Could it be hat you have a value of firstname that contains a single quotation mark or some other character that could interfere with the SQL statement?
You can also try putting the following at the very top (do NOT use ; for the delimiter in this case):
FME_SQL_DELIMITER #
This will ensure that FME doesn't try to split up the SQL statement before sending it to Oracle.
erik_jan
Forum|alt.badge.img+26
  • September 4, 2019
I believe you will need to add this at the top of your window:
FME_SQL_DELIMITER ;
  • September 4, 2019
FME_SQL_DELIMITER ;
thanks for your reply. now it threw "did not succeed; error was `ORA-00900: invalid SQL statement'. "
  • September 5, 2019
FME_SQL_DELIMITER #
gio
Forum|alt.badge.img+15
  • September 5, 2019
@wgsl2005
I think your syntaxis is off.
The ";" between the "when" should go and insert a "else"
Or add a "case" before the second "when" if the delimiter signifies a new sql snippet.
Row starting with just "when" seems not valid.
https://docs.oracle.com/cd/B19306_01/server.102/b14200/expressions004.htm
  • September 5, 2019
FME_SQL_DELIMITER #
Thank You So Much! i have debugged for a few hours for frustration and your solution worked.
so the solution is to add FME_SQL_DELIMITER #  on the top. the SQL statements are correct.
