help wms use
  • October 17, 2019
  • 5 replies
  • 28 views
Hello,
I would like to use this wms (in QGIS I can see the raster): https://geoservices.wallonie.be/arcgis/services/RELIEF/WALLONIE_MNT_2013_2014/MapServer/WMSServer?request=GetCapabilities&service=WMS
What url should I use to access this wms via FME.
Thanks a lot.
Forum|alt.badge.img+46
  • October 17, 2019
You can use that url directly in a WMS reader
Thank you @egomm
I try but I have this error when I try to load the layer list in a reader wms .
<WMS> Couldn't connect to server- Unable to fetch the capabilities document: 'https://geoservices.wallonie.be:443/arcgis/services/RELIEF/WALLONIE_MNT_2013_2014/MapServer/WMSServer?SERVICE=WMS&REQUEST=GetCapabilities&VERSION=1.1.1'
Do you have an idea of the problem?
  • October 17, 2019
Thank you @egomm
It could be a permissions/proxy issue - I'm able to connect to that url with no issue using the WMS reader
palhermans
Forum|alt.badge.img+11
  • October 17, 2019
Thank you @egomm
Maybe try to specify the version (1.3.0), i.e
https://geoservices.wallonie.be/arcgis/services/RELIEF/WALLONIE_MNT_2013_2014/MapServer/WMSServer?request=GetCapabilities&service=WMS&version=1.3.0
it was effectively a problem of proxy ... I make some modification and it works thank you very much.
