Attribute Values
  • May 14, 2013
  • 23 views
I want to update one record in an attribute.  For example, the attribute carries the names of several cities, I want to change just a single city name within the attribute.
dustin
Forum|alt.badge.img+31
  • May 14, 2013
StringReplacer should get the job done.
fmelizard
Forum|alt.badge.img+21
  • May 14, 2013
The string pair replacer can be another option.
hope this helps.
You might also consider a Test Filter (or a Tester) > AttributeSetter (ie change your attribute > "merge" your streams back together.
  • May 15, 2013
There may be several approaches, which  is optimal depends on the data condition and requirement. What kind of format is the attribute string?  Comma-separated, space-separated or other? You need always the first city name in the attribute?
Takashi
