insert image in dwg
  • December 13, 2014
  • 58 views
zzupljanin
Forum|alt.badge.img+5
Hi there,
Is there a way to insert image file (tiff) into dwg file. As external reference of course.
  • December 14, 2014
I've never tried, but this might help you.
FME Readers and Writers > Autodesk AutoCAD DWG/DXF Reader/Writer > Feature Representation > External References (http://docs.safe.com/fme/html/FME_ReadersWriters/Default.htm#acad/external_references.htm)
Takashi
gio
Forum|alt.badge.img+15
  • December 16, 2014
In AutoCad there is a command: Insert>RasterImage p.
You of cousre need to extract relevant geo-info from the image to have it reference correctly.
You can read the tfw with a textreader if it is a geotiff. Iff not, you might want to calculate or set the values by other means.
