KML Regionation from Master KML file
  • July 3, 2018
  • 10 views
I have a KML file containing a large set of lines/paths, I want to regionate the data and have it only display when it's zoomed in at around 16-20 miles screen scale in google earth if that makes sense.
danilo_fme
Forum|alt.badge.img+45
  • July 3, 2018
Hi @studio_318
Did you try to use the transformer
KMLRegionSetter ?
I believe that this transformer can it help you.
Thanks,
Danilo
