write to PDF
boubcher
Forum|alt.badge.img+11
How can I write attribute MSG to a PDF as text
ID MSG1inside the polygon2outside the area3close to the event area4comment
taojunabc
Participant
  • Participant
  • June 14, 2018
You need to first add the output coordinates of the text, then apply PDFStyler to determine the color of the text (if you need), and finally PDF output to PDF Writer.
boubcher
  • June 14, 2018
how the position of th text is defined on the pdf
boubcher
  • June 14, 2018
Forum|alt.badge.img+49
The VertexCreator makes fake geometry to attach the text to. You could add a PDFPageFormatter right before the writer to determine where the text ends up on the page.
boubcher
  • June 14, 2018
I get an error message ( invalid geometry ) just after the vertex transformer, is there any reason?
gio
Forum|alt.badge.img+15
  • June 14, 2018
use "replace" as parameter on the vertexcreator (not "add")
