Add features based on attribute value of existing features
  • November 28, 2017
  • 115 views
Hi there,
I have an existing spreadsheet and need to add in rows of information from a different spreadsheet based on the column value from the existing spreadsheet. I need to then write this to Excel again.
Any suggestions?
Thanks
  • November 28, 2017
Sounds like you should have a look at the FeatureMerger transformer.
  • November 28, 2017
Thanks David, I don't actually need to merge the attributes, I just need to order and duplicate the features based on the attribute value from the existing spreadsheet
  • November 28, 2017
Could you post some sample data here as well as the expected result?
  • May 28, 2019
I'm going to try this suggestion of using the "Cloner" transformer based on a Tester: https://knowledge.safe.com/questions/5076/how-to-duplicate-features-based-on-an-attribute.html
