Hi
I've set up a workspace to extract certain types of businesses (a MapInfo point dataset that I have a tester attached to to extract the types) that lie within an employment area (a MapInfo polygon table).
Using the Clipper function, this workspace runs fine and i get a result output into a MapInfo table.
The output table includes all the attributes from the point dataset, but i want to also include the attributes from the Employment Areas dataset (only 2 columns, but they're both useful) attached to each record in the output table.'
I have tried many of the Feature, Attribute and Spatial functions, but cannot get the 2 tables to be merged into one after the Clipper has extracted the data.
Apologies in advance if this isn't explained very clearly. Am a new user of FME so am still on a steep learning curve to understand what to do when when setting up a Workspace! Hopefully someone can answer my query
thanks
Simon Hume
