Resolving pagination with Httpcaller/loop
  • April 3, 2020
  • 7 replies
  • 393 views
Hello,
I am currently working with some scooter mds data and I am trying to find references to help with pagination. I would like to be able to call page one and use a json fragmenter to process and then go onto page 2, etc. Has anyone worked with something like this before or has some ideas? I'd love some input.
The API has links in the json that have "first", "next", "last" that reference the corresponding page number.
My thought was to keep referencing the "next" page url for processing until the last page: It looks a little like this:
next: http://(scooter provider mds)trips?end_time=(date/time)&page=2&start_time=(date/time)
http://(scooter provider mds)trips?end_time=(date/time)&page=3&start_time=(date/time)
bruceharold
Forum|alt.badge.img+19
  • April 3, 2020
Here is a workspace to give you the pattern:
githubreporter.fmw
  • April 3, 2020
githubreporter.fmw
@bruceharold I am running into the issue of the string searcher not matching with any values. Do you know why this would be occurring?
bruceharold
  • April 3, 2020
You'll need to get the regular expression working, the regex editor should help there. Maybe a case issue with next versus Next or something?
  • April 3, 2020
Thank you for the information! I actually ended up using a json extractor to call the "next" page.
flavien
  • September 23, 2020
githubreporter.fmw
Do you mind sharing your example workspace again? It seems the link is not working anymore..
bruceharold
Here you go.
flavien
Thank you!
