I have a project that converts a GML file into 6 individual shapefiles. I have mapped all the attributes from the GML file to different names in the shapefile in order to comply with the 10 character limit e.g -
featurecode > featcode
versiondate > date
Now I want to name the shapefile dynamically from a publish parameter so I used the attribute creator to create a new attribute called "feature_name" with the value:
$(name)_TopographicArea
and this outputs a shapefile with the correct name. so far so good......
The problem is the shapefile now contains multiple additional attributes that I didn't select or want in the resulting shapefile. How do i retain the schema mappings that I made?
Any ideas?
Mike
