FME server cannot find arcpy
  • April 25, 2016
  • 5 replies
  • 45 views
We are having trouble getting fme server find the arcpy libraries while executing a workbench using python caller to do some processing using the arcpy libraries. Where does fme server look for Python libs?
We are running fme server 2015
Best answer by jdh
From the documentation: http://docs.safe.com/fme/html/FME_Server_Documenta...
Uploading Python Modules to FME Server
If you have a Python module you need to use on FME Server which is not part of the Python standard library, use the Upload tool on the Resources page of the Web User Interface, and upload it to the folder under Engine\\Plugins\\python that corresponds to the Python release compatible with the module (for example, python27).
Note that to use arcpy you need to have a license available on the machine running the FME Engine.
jdh
Forum|alt.badge.img+40
  • April 25, 2016
  • April 26, 2016
Thanks for the response, a followup, for arcpy which files specifically should I upload ? There are quite a few of them..
jdh
  • April 27, 2016
As far as I know (never having tried it myself) the entire contents of ..\\ArcGIS\\Desktop10.x\\arcpy
I didn't install ArcMap on FME Server but installed the 64bit ArcPython library on the server and then uploaded it in the resources folder. I didn't get it to work. I'm hoping I don't have to have ArcMap installed because it's a 32 bit install vs the 64 bit server install I was hoping to use. --I'll do some more research and let you all know what I find out!
jdh
  • September 28, 2017
I believe you need to have arcGIS installed in order to check out a licence. Make sure to also install the 64-bit background geoprocessing. http://desktop.arcgis.com/en/arcmap/10.3/analyze/executing-tools/64bit-background.htm to use arcpy in 64-bit fme.
