Log message filter missing from FME Form 2024.2.3?
  • March 7, 2025
  • 60 views
jnknnn
Forum|alt.badge.img+5
In earlier versions of FME desktop/form i was able to filter log messages from options → translation → log settings. I know i can disable them in traslation log but we used those settings to control if server/flow logged warning messages. We have process that creates massive amounts of unnecessary warning messages that generates gigabytes of logs. Log message filter option doesn’t seem to be available anymore? Is it moved some other place?
FME 2024
FME 2022
j.botterill
Forum|alt.badge.img+55
  • March 7, 2025
To my knowledge, the transaction log runs in full and there are tool bar icons to filter it for the warning, error etc. severity. Not sure when or why they dropped this in the 2024 redesign...
You also have workspace defaults > max features to log
I suggest you update your workspace and edit the logger > severity. Alternatively consider adding a csv writer and direct all the warning to output into a separate log
jnknnn
  • March 12, 2025
That’s a weird thing to remove. Now there is now simple way to filter out warning messages from Flow.
