Spatial Relator keep causing my workbench to fail
  • July 1, 2024
  • 91 views
scottshenberger
Hello,
I am working creating a workbench that will take date for AGOL and from our sde database and join them together as a point feature for use in AGOL apps. All of a sudden, I get this error message:
ArcGIS Online Feature Service Writer: Encountered an unexpected error. The error code from the server was '405' and the message was: 'This SqlTransaction has completed; it is no longer usable.'. Details: 'Unable to apply edits. Please check your parameters.'
ARCGISONLINEFEATURES writer: An error has occurred. Check the logfile above for details
When I look at the log file I do not seem to locate any information. No sure what I am doing wrong.
Thanks in advance.
Scott
lambertus
Forum|alt.badge.img+24
  • July 2, 2024
@scottshenberger interesting case. Maybe you could try to delete your cache and rerun the workspace?
Furthermore I am not familiar with this error. Maybe there is something wrong with the AGOL source? You could also check whether all data fed into the SpatialRelator is valid.
crutledge
Forum|alt.badge.img+44
  • March 9, 2025
@lambertus Oh wow. This is a good find! I was having a similar problem and never knew about the ability to “Purge Temporary Files”. Brilliant!
