Dear all,
I need to add multiple REVIT/IFC files into an ArcGIS WebScene. I am trying to determine the most efficient way to achieve this.
From my understanding, the process should involve the following steps:
  1. Read multiple REVIT/IFC files from a given folder.
  2. Transform these files into Multipatch and save them into a Geodatabase.
  3. Publish the layers.
Do you think it is feasible to obtain such a result?
Many thanks.
PS: I found this post which contains a similar request:
Be the first to reply!
