Stop zip file from being split
  • May 30, 2024
  • 40 views
01011010
Forum|alt.badge.img+4
It is possible to the saved zipped file from the ShapeFile feature wrtiter NOT split (generate) multiple zip files. The workbence/job is running on FmeCloud.
andrewj74
Forum|alt.badge.img+7
  • May 31, 2024
if you are zipping out it should only create 1 zipped shapefile, unless you are fanning it out and have an attribute value as part of the naming convention?
