Exporting to GDB from multiple sources - only attribute info is visible and no geometry
  • April 2, 2024
  • 48 views
abnan0001
Forum|alt.badge.img+9
Hello All
I need your guidance to correct this issue..
  • I have few polygon layers with limited infomation in the layers.
  • I have an excel master sheet with complete details and common field is species name
    so , I have used feature joined after some transformation and got all details connected to layer..
    Now , The issue is when i have exported it to gdb , everything is blank without geometry and only attributes are visible for polygon layer..
    I want to project it to LL84
    I have attached workspace template and error screenshot
    I shall be thankful for suggestion
Best answer by nielsgerrits
I prefer to use a FeatureMerger instead of the FeatureJoinder. Geometry = Requestor, excel = Supplier. Right now, the records without geometry from Left overwrite the geometry of Right.
nielsgerrits
Forum|alt.badge.img+64
  • April 2, 2024
