FME Desktop Esri Edition with ArcGIS Desktop licensing requirements when running on a VM in a remote network
  • February 16, 2023
  • 61 views
ioan.pintilie
Hi!
I’ve recently installed and licensed FME Desktop Esri Edition (on 32Bit) on a VM within an isolated network. I need to use the ArcSDE Geodb Reader of FME, to have access to Network and Relationship information, and as a pre-requisite I’ve also installed the ArcGIS Desktop (by default on 32Bit). I have not yet licensed the ArcGIS Desktop that I’ve installed along with the FME. Still, I can call and start to configure the ArcSDE Geodb Reader.
My goal is to connect to several ArcGIS VMs within the same isolated network. I’ve received a bunch of .sde database connection files that I’ve used in the configuration of the ArcSDE Geodb Reader. I do not know exactly if these VMs that I’m trying to connect to are running just a database or have ArcGIS software installed and licensed as well (like ArcGIS Desktop, ArcGIS Server). I have little knowledge about the ArcGIS architecture. I know that there are several ArcGIS models dispersed on a bunch of VMs.
My problem occurs in the set-up of the ArcSDE Reader when I’m trying to select the Tables that I want to read (the .sde connection file is alright). I get what seems to be a licensing error:
“Could not open the Enterprise Geodatabase. The error number from ArcObjects is: '-2147220952'. The error message from ArcObjects is: {The Product License has not been initialized.}”
My questions would be: Do I have to license the ArcGIS Desktop that I’ve installed locally along with FME Desktop? Can I license the ArcGIS Desktop on this VM independent of the others ArcGIS installations in the network? Will it work? Or should I check the licensing procedure of ArcGIS for the other VMs in the network (should I check for a licensing server, or ask for a floating license)?
For sure a licensed ArcGIS is required; is it for the local ArcGIS installed as pre-requisite? I’ve consulted the following material:
-         https://community.safe.com/s/article/required-arcgis-license-types-for-fme-geodatabase
-         https://community.safe.com/s/article/geodatabase-formats-missing-greyed-out-or-have-unm
-         https://community.safe.com/s/article/notes-on-fme-and-esri-versions-and-compatibility
-         https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/geodatabase/GEODATABASE_SDE_reader.htm
Thank you for your thoughts!
Best answer by hkingsbury
The Esri Instance on the machine you're running FME on needs to be licensed. SDE reading/writing is a licensed operation opposed to a GDB where you can use either the API (free) or ArcObjects (licensed) based implementation
hkingsbury
Forum|alt.badge.img+54
  • February 16, 2023
ioan.pintilie
  • March 17, 2023
Hi @hkingsbury​! Thank you for the feedback. Indeed, FME has to be installed (and licensed with the Esri Edition) over a licensed version of ArcGIS (in my case ArcGIS Desktop) installed locally. To be able to actually retrieve all the tables that I need with the geometries and Network and Relationship information, the locally installed ArcGIS solution should be the custom one distributed on all the machines.
