How do I update the same field values across multiple schemas within a .gdb?
  • October 7, 2021
  • 0 replies
  • 26 views
hannahwh05
Forum|alt.badge.img+9
I have a gdb with domains with a lot of feature classes and tables. They all have 8 fields that are the same and the remaining fields vary from feature class to feature class.
I want to populate those same 8 fields with the same value for all the features but maintain their schemas.
I tried doing this with an attribute manager and writing with the template file geodatabase with the attribute definition set as dynamic. I've also tried adding the values to the attribute definition.
I know there must be a way, I just can't figure it out!
TIA
